Activity Forums Adobe Premiere Pro EMERGENCY CS4 JVC unsupported codec issue: Won’t Import
  • EMERGENCY CS4 JVC unsupported codec issue: Won’t Import
    Posted by Jordan Mederich on June 13, 2011 at 2:43 am
    I used the JVC HM100u and recorded onto .mov files to class 10 cards. I’m now seriously regretting it. The footage was a wedding.
    Normally the file hierarchy on JVC begins with BPAV, but I’m only getting a CQAV file with various XML files inside and mov files that won’t open or transcode.
    I’ve seen threads of others having similar issues, but with no for sure answer. Whenever I import, it loads, and then ends with “missing or unsupported codec” messages.
    I Shot 1080/60i and I’m editing on Premiere CS4 on an i7 tower. I never have problems with other footage or files, but this stuff is kicking my butt… SAVE ME!
    Kevin Monahan replied 15 years, 3 months ago 3 Members · 2 Replies
  • Mike Cohen
    June 13, 2011 at 1:25 pm
    Can the video files be played in VLC or QT player? If yes you may need to transcode. If not do the files play on the camera. If so maybe you can capture using a capture device such as Matrox mxo mini etc.
    If giles don’t play on camera you might be hosed.
    Was this the first time using this camera? If so surely you tested your workflow before jumping into a project.
    Mike Cohen
  • Kevin Monahan
    June 14, 2011 at 7:07 pm
    If it won’t work with Premiere Pro CS4, you can always try a 30-day free trial of Premiere Pro CS5.5. Since it is a fairly modern camcorder, you may have better luck.
    Link to trial of Adobe Master Collection CS5.5: https://www.adobe.com/cfusion/tdrc/index.cfm?product=master_collection
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
