Activity Forums Maxon Cinema 4D embossed logo on an object ?
  • embossed logo on an object ?
    Posted by Gareth Wrafter on December 14, 2009 at 3:49 pm
    I am trying to achieve the embossed gold ingot look I have used bump and displacement but these did not give me a clean enough render anyone have any suggestions to achieve this?
    Adam Trachtenberg replied 16 years, 9 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    December 14, 2009 at 4:18 pm
    I would start with bump — the key here will be to change the bitmap interpolation from the default “MIP” to a less blurry alternative, like Circle or Square.
    Same goes for displacement, but if you use that you’ll also need enough subdivision and you’re better off using a 16 bit texture map.
  • Gareth Wrafter
    December 15, 2009 at 9:36 am
    yeah I tried the bump and displacement with your further suggestions and I did get better results but are still not as clean looking it shows up as really pixelated
  • Adam Trachtenberg
    December 15, 2009 at 4:33 pm
    Hmmm…. Maybe you need to use a bigger bitmap?
