Activity › Forums › Maxon Cinema 4D › “Embossed” helix?
  • “Embossed” helix?
    Posted by Brandon Gallagher on June 13, 2011 at 4:09 am
    So I’m pretty new to Cinema, though in the last week or so I’ve managed to garner a decent understanding of the layout, and I can do some basic constructing. I’m planning on eventually constructing this: https://farm3.static.flickr.com/2634/4279564674_5679e36ab5.jpg
    The mecha has large drills, but the spiral that runs along the cone is “dug” into the cone, and I’m not sure how to go about that. I’ve managed to make a helix, with a triangle set to take it’s shape, and had that run along the drill, which produces the opposite effect, albeit still making a drill. So how can I cut into a shape like that?
    Greg Burrus replied 15 years, 3 months ago 2 Members · 3 Replies
  • Greg Burrus
    June 13, 2011 at 3:44 pm
    I actually just created this effect on a model I made a little while ago. https://g2b.deviantart.com/art/3D-NutCracker-209524402
    All I had to do was use a boole which is in objects > modeling menu and subtract one object(helix spline) from the cone part. If you need more help I can send you the drill part of my model so you can see how I did it but the effect is fairly straight forward once you have it lined up right.
    Good luck making the model.
    “Go beyond the impossible and kick reason to the curb!”
  • Brandon Gallagher
    June 13, 2011 at 5:00 pm
    All right, I heard mention somewhere of doing that, but I wasn’t exactly sure. Thanks for the help!
  • Greg Burrus
    June 13, 2011 at 5:20 pm
    No problem glad I could help
