Activity Forums Apple Final Cut Pro Legacy Embedding REC 709 into pro rez .mov
  • Embedding REC 709 into pro rez .mov
    Posted by Vasilis Chatzivasileiou on August 25, 2010 at 11:47 am
    Hi all
    I have a 12 min short that is to be transfered to 35mm. AT the lab they told me that they need a ProRez 444 file (no problem there) with the REC 709 profile embedded into it. I have no clue with regard on how to achieve that. The short was shot on XDCAM EX, 1920 X 1080 25p, edited in FCP 7.x and graded in color. Any help would be greatly appreciated.
    Vasilis
    Vasilis Chatzivasileiou replied 16 years ago 2 Members · 2 Replies
  • John Fishback
    August 25, 2010 at 7:41 pm
    I know that in Compressor’s Inspector in the Filters tab you have the option of specifying 709 color space. However, that may be the default color space for ProRes4444. Someone more expert than I may chime in with more detaila.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Vasilis Chatzivasileiou
    September 7, 2010 at 5:18 am
    Sorry for the late reply. Thanks for your tip. Compressor calls it HD 709!
