Activity › Forums › Adobe After Effects › embedded alpha channel
  • embedded alpha channel
    Posted by S. Marcotte on November 28, 2007 at 9:45 pm
    Learning Keylight. The documentation says: “If more than one
    mask is required to remove garbage, then use the masks to
    create an embedded alpha channel…”
    This is from a section on Inside masks. I get the idea, but how do I go about creating an “embedded alpha channel”? Does it require a render?
    Thanks in advance – SGM
    S. Marcotte replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
