Activity Forums AJA Video Systems Embedded AES signals from Kona LHe. Channels are missing
  • Embedded AES signals from Kona LHe. Channels are missing
    Posted by Sven Giebel on March 7, 2009 at 2:17 pm
    For a long time we have a problem with the audiooutput from our LHe. We have a HD/SD 8 Channel AES Embedder/Disembedder behind our card because we need to output 4 AES/EBU channels (twice stereo). We feed this disembedder with the SDI signal from the LHe.
    The disembedder has 4 XLR outputs on its breakout cable called output A,B,C,D.
    On B there should be channels 3 and 4, but unfortunately they are not.
    Threetimes we changed the HD10AM, we also changed the breakoutcable. A service technician from our distributor changed the Kona LHe. After he fiddled around with the dipswitches on the HD10AM the card-disembedder-combo worked as expexted, but only for a day. On the next restart channels 3 and 4 were dead again.
    We have a workaround for this (we use channels 1-2 and 5-6 as the audiooutputs), but of course we’d be glad if we could solve this thingie.
    Anyone here with similar experiences or a suggestion?
    Thanks a lot!
    Sven
    ps of course I contacted the nice people from Aja on this. They suggested to try a new card which we did. Hadn’t heard of this problem before.
    Sven Giebel replied 17 years, 6 months ago 2 Members · 6 Replies
  • Jeremy Garchow
    March 8, 2009 at 1:50 am
    Is your timeline setup for 4 channels of output and have you assigned the tracks properly?
  • Sven Giebel
    March 8, 2009 at 7:30 pm
    Thanks Jeremy,
    yes, everything is set up properly.
    Sven
  • Jeremy Garchow
    March 8, 2009 at 8:41 pm
    Do you have a KBox or are you using the breakout cables to the deembedder?
    Jeremy
  • Sven Giebel
    March 8, 2009 at 10:59 pm
    We have a KBox attached to the card.
  • Jeremy Garchow
    March 8, 2009 at 11:11 pm
    Try bypassing the KBox with the breakout cables that were supplied with your Kona.
    Then call AJA.
    Jeremy
  • Sven Giebel
    March 9, 2009 at 8:20 am
    We didn’t try that yet. Thanks for your help, Jeremy!
    Sven
