Activity Forums Adobe Photoshop Embed a File into Multiple Files at Once?
  • Embed a File into Multiple Files at Once?
    Posted by Kevin Camin on July 31, 2014 at 1:13 am
    I’d like to embed a .PSD file into multiple .PSD files in one ‘m opstroke inside PS CC. Is there a way to do this? I’m working on a set of products that get the same screen and the screen is a separate file. Best case scenario is that it could Place inside the multiple PSD files in a “linked” state so that one change to the Linked file would cause a spontaneous update in all the files.
    Thanks for reading.
    Best regards,
    Kevin Camin
    Jonathan Ziegler replied 12 years, 1 month ago 2 Members · 1 Reply
  • Jonathan Ziegler
    July 31, 2014 at 1:12 pm
    You’d likely have to use some type of script to automate the process – place a linked file into a folder full of psd files or something like it. May be able to automate the process with a recorded action and then use Image Processor to do a whole folder.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
