Activity › Forums › Maxon Cinema 4D › Embarrassing Question
  • Embarrassing Question
    Posted by Craig Wall on October 23, 2010 at 8:49 am
    I am stumped by something that should be (and I’m sure is) ultra simple. I’ve used c4d for a couple of years and every time this comes up I use some kludge.
    The question is this: What is the simplest way to fade up or fade down the alpha of an object and also its texture? (I’d want to control them independently)
    A variation of this question: if I want to fade the alpha of one material to a second when I’m using mix. (layers won’t cut it because one is a texture and the other a shader)
    Thanks in advance. (yes this is embarrassing)
    Life is full of funny particles.
    Craig Wall replied 15 years, 11 months ago 2 Members · 2 Replies
  • Randy Johnson
    October 23, 2010 at 10:11 am
    Uploaded with Skitch!
    These should get you started.
    /Randy
  • Craig Wall
    October 23, 2010 at 4:04 pm
    Thanks, Randy. Your reply was very helpful!
    I kept thinking there would be a simple attribute like in AE. I had not used the Display tag. That’s the quick way, it appears…which is what I was looking for.
    Yes, using a gradient within the alpha channel is powerful for wiping an object in, from any angle or from the core out, etc.
    Again, many thanks.
