Activity Forums DSLR Video Elgato Turbo H.264 slows down to 1fps!?!
  • Elgato Turbo H.264 slows down to 1fps!?!
    Posted by Aaron Steven on January 24, 2011 at 8:49 pm
    Hi all.
    So I purchased the Elgato Turbo.264 HD encoder a while back and I have been using it frequently. Despite the crushing of some blacks, its a great program. But recently after updating to version 1.1.3 the program doesn’t seem to work…at all. I’ve tried a variety of compression settings and my most standard is nothing extra strenuous. Im crushing footage from a Canon 5DMKII to 1280×720 with a data rate of 5000. If you are familiar with vimeo’s upload guidelines for HD, those are the exact settings I am using.
    When I start the compression within seconds El Gato stretches out to 001fps and the time goes sky high. I don’t understand, these are the exact same compressions I have been doing for over a month.
    Im on a Mac G5 with Dual 2.8Ghz Quad-Core Intel Xeon Processors and 6 GB of 800MhZ DDR2 ram, so Its not my system..
    Anybody encounter this before? Thanks in advance for any help.
    -Aaron
    Zane Barker replied 15 years, 7 months ago 3 Members · 2 Replies
  • Rafael Amador
    January 24, 2011 at 9:58 pm
    [Aaron Steven] “When I start the compression within seconds El Gato stretches out to 001fps and the time goes sky high. I don’t understand, these are the exact same compressions I have been doing for over a mon”
    Did you had a look to the Activity Monitor?
    rafael
    http://www.nagavideo.com
  • Zane Barker
    January 25, 2011 at 7:56 am
    [Aaron Steven] “Im on a Mac G5 with Dual 2.8Ghz Quad-Core Intel Xeon Processors”
    Well which is it a G5 or an intel, because it cant be both.
    The Elgato Turbo.264 HD is Intel only.
    https://www.elgato.com/elgato/na/mainmenu/products/Turbo264HD/product3.en.html
    As for issues with the Elgato Turbo.264 HD, this clearly is NOT a Elgato Turbo.264 HD forum. I would recommend going to Elgato’s Forums.
    **Hindsight is always 1080p**
