Activity › Forums › Adobe After Effects › Element 3d Object Rotation
  • Element 3d Object Rotation
    Posted by Virendra Chandekar on April 14, 2020 at 11:31 am
    Hi all,
    While Creating an animation where characters of text rotate and settle in place, if I increase the rotation value beyond 180 degrees the animation flips. If the Rotation degrees is set at 355 degrees the animation that happens is only 5 degrees rotation.
    Object is animated using ANIMATION ENGINE
    Multi-Object Enabled for both groups
    Start group 1 – X Rotation set to 0x + 355
    Start group 2 – X Rotation set to 0x + 0
    All help appreciated
    Thank You
    Richard Garabedain replied 6 years, 5 months ago 2 Members · 1 Reply
  • Richard Garabedain
    April 14, 2020 at 9:30 pm
    use group nulls to rotate past the 180 limit…not animation engine…
