Element 3D JETSTRIKE
Can anyone please help me achieve what Andrew Kramer did in this tutorial? https://www.youtube.com/watch?v=nZtmLCaYoHc
The tutorial is about the “Heat Distorsion” plugin, but I’m interested in one aspect which is not explained in the tutorial.
How to create that afterburn so it will look like is inside the engine exhaust? And how to link it to the exhaust ?? (when the exhaust moves the afterburn moves with it)
I’ve literally tried everything: I’ve moved the exhaust into a separate group in Element3D, created Nulls…it did’t work..
So please if you can manage to find a solution to this, please enlighten me.
Thank you in advance.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
