Activity Forums Adobe After Effects Expressions Elegant “Current” Keyframe solution?
  • Elegant “Current” Keyframe solution?
    Posted by Jon Wooley on March 22, 2016 at 8:27 pm
    I love the nearestKey(time) expression and have been using it to trigger animations with (time – nearestKey(time).time). However, nearestKey looks both forward and backward when determining which Keyframe is the nearest. I would love it if it only looked backward. I have to wonder if anyone in this community has figured out an elegant solution to this problem. I’ve tried a few different things based on my relatively limited knowledge of AE Expressions/Javascript Here is what I’m currently doing. There has to be a better way, right?
    x = thisComp.layer("Test").effect("Slider Control")("Slider");
    y = x.nearestKey(time).index;
    d = (time - x.nearestKey(time).time);
    if (d>=0){
    currentKey = y; //if the time between the playhead and the nearest keyframe is positive, the current key is the nearest key
    }else{
    currentKey = y-1; //if the time between the playhead and the nearest keyframe is negative, the current key is the previous key
    linear(currentKey,1,100,1,100) //keeps currentKey value above 0 since it will be used for index. Doesn't work if over 100 keyframes in effect.
    d = (time - x.key(currentKey).time);
    Jon Wooley replied 10 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 22, 2016 at 8:37 pm
    Something like this maybe:
    n = 0;
    if (x.numKeys > 0){
    n = x.nearestKey(time).index;
    if (x.key(n).time > time) n--;
    if (n > 0)
    d = time - x.key(n).time
    else
    d = 0;
    Dan
  • Jon Wooley
    March 23, 2016 at 6:26 pm
    You are a wizard sir. I continue to learn so much from you.
    Thank you.
