Activity › Forums › Blackmagic Design › EIZO monitor, DeckLink 3D+ and HDLink
Mike Nagel replied 12 years, 5 months ago 7 Members · 29 Replies
Luis Otero
October 2, 2013 at 2:47 pmI said the original HDMI. Both came out more or less at the same time, but due to cheaper cost of manufacturing, HDMI was widely deployed, and further upgraded.
Ericbowen
October 2, 2013 at 5:34 pmDid you try the output with SDI to the HDlink and DVI to the monitor? Did you try the 59.94 frame rate yet? have you tried 720P60 yet?
Eric-ADK
Tech Manager
support@adkvideoediting.com -
Luis Otero
October 2, 2013 at 6:13 pmThe HDLink that I own has DiplayPoty output, not DVI or optic fiber. I tried DP to DVI adapter, but it does not work. The only option that works is DP to HDMI via adapter and going back to DVI in the monitor, but the signal is Pink. Aside, DVI is, as far as I know, 8 bit connection. If I could fix the color Pink issue, and I can confirm that the DVI can carry the 10 bit signal from the HDMI, then I have it solved.
Ericbowen
October 2, 2013 at 6:22 pmThe DVI input on the monitor wont carry the 10Bit. That will be 8Bit. You have to go into the monitor Displayport to get the 10bit. Did you see if Eizo had a firmware update?
Eric-ADK
Tech Manager
Luis Otero
October 2, 2013 at 7:27 pmI can check, but this unit was manufactured on June/2013. Will try to check with them. However, it seems to me that the issue could be HDLink capability, or lack of. Will try to call Dwaine to see if there is some other angle I have not thought of yet.
Luis
Nick Price
October 3, 2013 at 12:53 pmHi
i presume you have been through all the menus to see if you can change the colour space to REC709. I have a dell monitor that i can use as a simple video reference monitor. It is plugged in using the same DVi cable, driven either from a blackmagic HDMI or the computer graphics card. To switch between ‘video’ and ‘computer’ there is a setting in the menu called, rather simply, ‘computer’ or ‘video’. One is pink when switched incorrectly.thanks
nick -
Luis Otero
October 3, 2013 at 2:02 pmThanks for the information, Nock. I do own a Dell and it also has such setting. In this monitor, the selection of RGB or YUV is done automatically by the monitor.
Thanks!!!
Jesse Coane
October 4, 2013 at 5:26 pmOpen the HDLink utility go to settings and make sure “scale video to fill larger display” is checked. does that help?
Director / Editor
http://www.jessecoane.com
@jessecoane -
Mike Nagel
April 7, 2014 at 7:15 amHi guys,
if you’re calibrating the Eizo directly with a 3D LUT (the HDLink’s LUT is smaller and the LUT processing is bad) then here’s a very detailed calibration & workflow guide comparing Lightspace & ColorNavigator calibration approaches:
Eizo CG275W Calibration Guide Using Lightspace And ColorNavigator
– Mike
Profiling & Calibration Workflow Tools: http://www.DisplayCalibrationTools.com
