Activity Forums Apple Final Cut Pro Legacy Effects wont take effect :(
  • Effects wont take effect :(
    Posted by Rebecca Croft on August 5, 2008 at 7:23 pm
    I’m using FCP 5 with Panther and I suddenly find that effects don’t work any more. I drag and drop them onto the clips in the timeline and absolutely nothing happens. None of them work and I need to do some major color correcting ASAP.
    Everything else works fine and I can continue editing, adjusting audio levels and adding transitions. I’m not getting any error messages.
    I’ve tried uninstalling and reinstalling FCP 5 but to no avail. I tried dumping preferences. I even tried using Disk Utility to repair/verify permissions. I was referred to a program called Disk Warrior, but it seems to only work on Tiger or Leopard and it costs $100. I’m not yet ready to upgrade to 6 either. There has got to be a solution to this. Can anyone help? Thank you in advance 🙂
    Rebecca Croft replied 18 years, 1 month ago 2 Members · 2 Replies
  • Ben Holmes
    August 5, 2008 at 10:31 pm
    check your settings. Have you got ‘play base layer only’ checked in the RT drop-down top left of the timeline? Check the render settings also in system settings….
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Rebecca Croft
    August 6, 2008 at 12:33 am
    Because of what you said I decided to look more into the settings and preferences. So I went to video processing under sequence settings and checked “Always render in RGB” and it worked! “Render in 8-bit YUV” is what was checked before. I’m not sure why or how but it works now!!!
    Thank you for helping 😀
    By the way ‘play base layer only’ was not checked
    ~R
