Activity › Forums › Apple Final Cut Pro Legacy › Effects will not render
  • Effects will not render
    Posted by Glenn Grant on May 22, 2008 at 12:43 am
    I have searched here and on Apples site and have not found anything on this.
    I am running FCS 2.0.3 on a 2×2.8 quad core with 10 GB memory. With the stock ATI 2600 graphics card.
    I capture HDV footage via firewire to ProRes, not HQ, just regular HD. Some of the stock Apple effects and filters will not work. I get an error saying “The effect “Defocus” cannot be rendered in a sequence of this size with the current graphics card.” This happens with a number of the Apple effects as well as plug ins from BCC.
    I tracked this down to the render options in the time line settings.
    When “render in 8 bit” is selected everything is fine. When I select “Render 10-bit…” then I get the error.
    Can someone explain this to me so I am clear on the subject before it is an issue? Is this just something that comes up because some of my settings don’t match, or is this graphics card not capable of handling 10 bit material?
    Rafael Amador replied 18 years, 4 months ago 2 Members · 1 Reply
  • Rafael Amador
    May 22, 2008 at 3:53 am
    Thas clear Glenn,
    This happens with the GPU based effects. Those are rendered in your video card. s your computer is telling you, your video card is not enough to cope with that data-rate.
    nothing to do apart of getting a better video card.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
