Activity Forums Apple Final Cut Pro Effects suggestions
  • Jeremy Garchow
    May 25, 2018 at 1:20 am
    Are you snorting green screen or what’s the background?
  • Russell Smith
    May 25, 2018 at 2:52 am
    Dark black BG
  • Jeremy Garchow
    May 25, 2018 at 5:13 pm
    Perfect. Good thing you aren’t snorting green screen. Bad for the health! ☺
    You could do this manually with Motion and a either clones or replicator, but a quick search turned up a plugin that might be better for you.
    https://store.pixelfilmstudios.com/product/proarray/
  • Jeff Kirkland
    May 25, 2018 at 10:25 pm
    Can’t help with a specific recommendation but the effect is reminiscent of Motion’s WideTime filter and I know it’s a an effect I’ve seen a lot in various live VJ apps.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Brett Sherman
    May 27, 2018 at 1:32 pm
    If you are so inclined, you could make a Motion Template that does this. Looks to me like the original layer is keyed on top with a luma key. Then cloned layers underneath also with luma key and Colorization, with a horizontal offset. You’d also want to keep a clone of the original layer on the bottom too, without a key.
