Activity › Forums › Apple Final Cut Pro › Effects Presets Tip
  • Effects Presets Tip
    Posted by Oliver Peters on June 27, 2015 at 8:56 pm
    Here’s an interesting tidbit made possible with 10.2. You can now save Effects Presets. This is also helpful with Color Board Presets and not just other effects. Those presets can be saved as before, but you can’t hover over any and see what they might look like until you apply them.
    However, if you apply the Color Board Preset or create a new setting and then save that as an Effects Preset, it will show up within the category you assign in the Effects Palette. Once it’s there, you can hover over the icon and get a preview of the look as it’s applied to your image. Once applied, you simply tweak the Color Board settings as needed.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Noah Kadner replied 11 years, 3 months ago 2 Members · 1 Reply
  • Noah Kadner
    June 28, 2015 at 4:35 am
    Yup love this. The one step backward in regard to Color Board for me is that now it becomes a second instance of Color Board when Copy>Pasting Attributes. So you have to be really careful if you paste a Color Board to a clip with an existing color board- you’ll now have two color corrections. I wish there would be the option to add as an additional color board effect or overwrite the existing.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
