Activity Forums VEGAS Pro Effects not showing up on rendered YOUTUBE vid(SONY PLAT 8)
  • Effects not showing up on rendered YOUTUBE vid(SONY PLAT 8)
    Posted by Doris Goodmen on September 22, 2009 at 9:42 am
    my problem is (and this is weird)
    when im working on my video and using effects it looks fine in the preview screen BUT when i render it and upload 2 YOUTUBE at 640X480 or higher, the effects are messed up BUT when i render it at 320X240 or lower and upload 2 YOUTUBE the effects show up just fine.
    PLEASE HELP because 340×240 is REALLY CRAPPY QUALITY
    Jean-jacques Boug replied 14 years, 8 months ago 3 Members · 2 Replies
  • Mike Kujbida
    September 22, 2009 at 12:42 pm
    What format are you rendering to?
    What does it look like when you play the rendered version before uploading it?
    How are the effects “messed up”?
    Post a link so that we can see what “messed up” means and maybe we can offer some suggestions.
  • Jean-jacques Boug
    December 14, 2011 at 5:02 pm
    I think I have the same issue as mentionned above.
    I have 2 scene with quick flashes which are 1 or 2 frames long, and in Vimeo/youtube half or 2/3 of the flashed are missing.
    Here are the source details :
    1280×720 (1.0)- 59,94 FPS Progressive 48000 Hz Stereo
    Output :
    NTSC 1280×720 59,94 FPS Progressive AAC 192kbps 48000 Hz Stereo Widescreen 16:9 (tried with squared pixels)
    VBR 2 pass Targe 6 Max 10
    Here is the uploaded : https://vimeo.com/33647809 (@ 1:36 and 2:07)
    I had the same issue on another one in youtube, were it seems to be slightly laggy :
    https://www.youtube.com/watch?v=W6p2eBgyqAY&feature=related
    I use Adobe Premiere Pro Premium Production 5.5
    Thank you
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
