Activity Forums Adobe After Effects Effects display much less pronounced outside of comp
  • Effects display much less pronounced outside of comp
    Posted by Miguel Dey on April 11, 2012 at 3:21 pm
    This is a strange one. I have a comp that we’ll call comp 1 that contains 2 other nested compositions. The effects inside of those nested comps display correctly and the effects display correctly when showing in comp one but when I put comp 1 of my main composition the effects are barley visible. There are no layers above comp 1 in the main composition and no adjustments or effects on the composition as well. The blending mode is also set to normal. Any ideas as to what is causing this.
    Walter Soyka replied 14 years, 5 months ago 4 Members · 4 Replies
  • Benjamin Ausmith
    April 11, 2012 at 3:47 pm
    Try turning on continuous rasterization?
    Benjamin Ausmith
    Post-Production Assistant
    Monadnock Media, inc.
  • Darby Edelen
    April 11, 2012 at 4:06 pm
    Are you previewing at Full resolution? What effects are we talking about here? Are there blend modes being used in effects in the pre-comps?
    Darby Edelen
  • Miguel Dey
    April 11, 2012 at 6:10 pm
    I figured out the problem now, I turned off OpenGL rendering and everything is now displaying correctly. Appreciate the responses.
  • Walter Soyka
    April 11, 2012 at 7:28 pm
    [Miguel Dey] “I turned off OpenGL rendering and everything is now displaying correctly. “
    AE’s OpenGL renderer is the devil.
    You can use the OpenGL Fast Preview if you like, but as you have found, the OpenGL renderer’s output should always be considered non-final.
    Walter Soyka
