effects cause image to change size
hi all,
i’ve got a really bizarre error… i’m working in premiere pro 7. an exported sequence displays correctly on-screen when the material is just a segment of untreated source image. however, whenever i have a section that i’ve treated w/an effect, the image becomes smaller; the playback screen displays the image w/black borders. the a/r appears to remain constant, however. the effects i’m using are pretty simple: cross-dissolve and color correction. the magical shrinking image phenomenon lasts only as long as the effect is… well, in effect! then the image returns to normal size.
project settings:
– widescreen pal, 48khzinput files:
– source material: dv captured directly by premiere
– file format: dv type 2 avi, avi v.2.0, dvc/dv codec
– a/r: sar=5:4, par=16:10, dar=4:3
– 25fps, 720×576 [pal]
– audio 48khz stereooutput file:
– same as source, except avi version is 1.0any help on how to make the output stop doing that would be greatly appreciated! thanks!
