Activity › Forums › Maxon Cinema 4D › Effector Fields Question – If cloner has a material, can you use the Color Remap of the Field?
  • Effector Fields Question – If cloner has a material, can you use the Color Remap of the Field?
    Posted by Rob Mason on June 20, 2019 at 5:42 pm
    My question is as above. I cannot seem to be able to have BOTH a cloner with a material and make use of the Color Remap function within any of the effector fields.
    Anyone know how to do this?!
    I really need the texture of the material, but I also need to make use of the great falloff and animation parameters of the Field Color Remap…
    Freddy Fernow replied 6 years, 10 months ago 3 Members · 4 Replies
  • Brian Jones
    June 20, 2019 at 6:37 pm
    with a Node material you can pass the color from a MoGraph node (in the Info group) into the color of the BSDF node and get the Field color remapping. I don’t know how to do it in standard materials
  • Brian Jones
    June 20, 2019 at 6:53 pm
    Found it, in a standard material you can just add a Mograph Color Shader (set to Color in Channel) and that seems to do it
  • Rob Mason
    June 20, 2019 at 7:48 pm
    You’re a lifesaver.
    Worked!
  • Freddy Fernow
    November 13, 2019 at 3:37 pm
    i stumbled upon your post and i am having the same problem. I just cant figure out where to put the mograph shader under the standard material?
    My cloner has one texture but i want to keep the color remap.
    Could someone help me out?
    Freddy
