Activity › Forums › Maxon Cinema 4D › Effect the seed of a Discplacement object’s noise shader
  • Effect the seed of a Discplacement object’s noise shader
    Posted by Devin Halladay on April 12, 2019 at 3:03 pm
    Hi!
    I have a cloner cloning some spheres. The spheres all have a Displacer on them, with a noise shader attached.
    I need to find a way to change the seed parameter of my Displacer’s custom noise shader for every clone in the cloner. I tried playing around with mograph effectors but couldn’t figure out a way to effect parameters other than the displacer’s position, scale, and rotation. Is it possible to do this kind of behavior? Maybe with xpresso or a step effector or something?
    Brian Jones replied 7 years, 5 months ago 2 Members · 2 Replies
  • Devin Halladay
    April 17, 2019 at 4:20 am
    Solved on my own, the solution was to set the shader’s noise space to “World”.
  • Brian Jones
    April 17, 2019 at 1:58 pm
    which will be fine as long as the clones don’t move
