Activity Forums Adobe After Effects Effect Syncing to sound
  • Effect Syncing to sound
    Posted by Lorenzo Escalante on February 16, 2009 at 11:39 pm
    Is there a way to Sync an Effect or the movement of an object to the sound of music, or is that something has to be done manually. I am currently trying to sync scratching on a turntable to the “wiggle” of an object I created AI. Is this possible?
    Lorenzo Escalante replied 17 years, 7 months ago 3 Members · 3 Replies
  • Todd Kopriva
    February 17, 2009 at 1:31 am
    You can use the Convert Audio To Keyframes keyframe assistant to get you much of the way to this result.
    Aharon Rabinowitz has a good tutorial about this keyframe assistant here on the COW.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Tom Scott
    February 18, 2009 at 1:25 am
    “You can use the Convert Audio To Keyframes keyframe assistant to get you much of the way to this result.”
    Or, for more control/options, you could take a look at Red Giants Sound Keys.
    Aharon has a tutorial on using Sound Keys to control time.
  • Lorenzo Escalante
    February 19, 2009 at 11:29 am
    In his plug In tutorial, he talks about AE can already accomplish what I am trying to do without the plug in. I am trying to make the scaling of a picture adjust to the sound of a song. Where can I find THAT tutorial? and Thanks for every one whose helped so far!! moooooo!
