Activity › Forums › Avid Media Composer › effect problem
  • effect problem
    Posted by Michael Thomson on September 4, 2005 at 8:53 pm
    Hi Guys
    Added advanced lens flare to a cut as a transition.
    (Boris CC, Adrenaline 2.1.6 PC)
    When i was in Effect editor the effect seemed to only apply to the A side of the cut, even when rendered.
    For example it was added centered for 15 frames, so the whole fifteen frames of the effect appeared on the a side then cut to the b side late
    any ideas?
    Michael Thomson replied 21 years ago 2 Members · 2 Replies
  • Grinner Hester
    September 8, 2005 at 2:57 pm
    Add edit where you want it to start, add edit where you want it to end and build the lens flair over a quick dissolve benieth it.
    I almost always use these effects as filler rather than applying to clips.
  • Michael Thomson
    September 10, 2005 at 11:08 am
    Hey Grinner
    Cheers for the advise, makes perfect sense
