Activity Forums Apple Final Cut Pro Legacy Effect of upgrading FCP 4.5 to 5.1
  • Effect of upgrading FCP 4.5 to 5.1
    Posted by Leo Ganzon on March 21, 2007 at 3:54 pm
    Hi FCP Fanatics!!!
    I am currently working on a Mac G5 system (not the intel proc) which runs on FCP 4.5 with a lot of plugins to boot. I researched the process of upgrading the 4.5 to 5.1 and it says that the system files of 5.1 overwrites that of 4.5. In effect it kinda makes a clean install of the FCP suite because you don’t have to uninstall the 4.5 manually.
    My only concern is the effect it has on 3rd party softwares like the plugins.
    Will it delete the plugins or will it work straight from where you left of? Is it compatible will the 5.1 suite or will you have to purchase a new set of plugins?
    Hope you fanatics can help out.
    Mark Maness replied 19 years, 5 months ago 2 Members · 1 Reply
  • Mark Maness
    March 21, 2007 at 4:29 pm
    Clone your drive and then install.
    If anything is messed up, you can boot to your clone drive with all of the old versions still intact.
    [demitkadet] “Will it delete the plugins or will it work straight from where you left of? Is it compatible will the 5.1 suite or will you have to purchase a new set of plugins?”
    As for this… That will all depend on your plugins. Most of them will need to be upgraded, too.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
