Activity Forums Adobe After Effects effect of bullet going past a parson like he’s a ghost
  • effect of bullet going past a parson like he’s a ghost
    Posted by David Lieberman on April 29, 2008 at 5:10 pm
    hello,
    ive got footage of an actor shooting another actor. the one being shot is meant to be some sort of demon/ghost. Im looking for effects that will make the viewer believe that the bullet travels through the demon without hurting it?
    I’ve got muzzle and light flashes, and i have a spark on the trashbin which the bullet hits behind the demon, the only thing missing is making it look like something just went passed the demon without hurting it..
    any ideas?
    thanx for the help.
    Jeremy Fabiano replied 18 years, 4 months ago 4 Members · 3 Replies
  • Roland R. kahlenberg
    April 29, 2008 at 5:21 pm
    One of the Distort tools, perhaps Mesh Warp to give a sense that pressure is being applied to the point of contact for the bullet will be good to have. Not too sure if you need debris-like particles for the entry and exit. Multiple instances if Particle Playground should do the trick for these.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Joey Foreman
    April 29, 2008 at 10:40 pm
    Bullet effects should be done a little differently for members of the clergy. You should probably consult a vicar.
  • Jeremy Fabiano
    April 30, 2008 at 7:24 am
    just posted a very very similar regarding a bullet going through a demon…
    i told him to try a displacement map.. for more info click Aharon’s head up top – he’s got 3 tutorials on displacement maps 🙂
    hope this helps
    -jeremy
