Activity › Forums › Adobe After Effects Expressions › Effect Name or index?
  • Effect Name or index?
    Posted by Ryan Hill on July 20, 2009 at 5:20 am
    So I recently did something with 10 beam effects applied to the same layer. I set the start and end point of each beam according to a formula, based on a variable I called “i.”
    Now, in this case, I just went ahead and set i=1, i=2, i=3 etc. for each beam effect. And this meant I had to set it for both the start point and end point of each.
    But it got me to wondering. Is there a way to either:
    1) Get the numerical index of the effect, in the sense if this beam is the 4th effect applied to this layer in order, then I want to get the number 4.
    2) Get the name of the effect (not the layer) and extract a number from that. (I can easily create beam1 beam2 beam3 just through duplication.)
    Dan Ebberts replied 17 years, 2 months ago 2 Members · 1 Reply
  • Dan Ebberts
    July 20, 2009 at 1:12 pm
    You can use propertyGroup() to move up 1 or more levels in the property hierarchy. So to get to the Beam effect level from the Starting or Ending point would be like this:
    thisProperty.propertyGroup(1).propertyIndex
    or,
    thisProperty.propertyGroup(1).name
    Dan
