Activity › Forums › RE:Vision Effects › Effect looks light then gets better Why? I have trial version.
  • Effect looks light then gets better Why? I have trial version.
    Posted by Adam Berch on April 22, 2013 at 10:58 pm
    HI,
    I noticed that when I put the RE:MATCH effect on a clip it looks great. It matches the clip exactly. That is with the playhead not moving
    When I press play, I can see that the clip with the effect starts off lighter than it looked when it was not playing, (It actually looks like it did before I added the effect) then as it plays, it eventually gets to the point where it looks like it did when I first put the effect on (Perfect)
    Since I downloaded and installed a trial version, is that the watermark or something? When I do purchase a serial #, will this happen?
    I cannot have the shot start one color and end in a different color. It needs to be consistent all the way through. It needs to look like it does when I first put the effect on and stay that way throughout the time the clip is on the screen.
    Thanks Again,
    Adam
    Adam Berch replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
