Activity › Forums › Apple Final Cut Pro Legacy › EDL question
  • Posted by Roli Rivelino on January 28, 2011 at 9:51 am
    I’m cutting a multi format project, from EX to, 35mm to mini dv through to Digi beta.
    At the end I’m going to produce an EDL for it to be blown up to 35mm, as I’ve never done this before I’m wondering; do I have to keep the tapes to give over along with the EDL or is a copy of the media folder within the capture scratch enough?
    And are there any other things I should keep an eye on as far as producing an EDL is concerned?
    Many thanks.
    https://www.rolirivelino.com/
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Roli Rivelino replied 15 years, 8 months ago 2 Members · 2 Replies
  • Shane Ross
    January 28, 2011 at 10:24 am
    If you plan on going to film…you need to consult with the company that will be doing the film output. Only then can tell you exactly what they need from you. THe rest of us are blind, and will give you bad advice on that front.
    Shane
  • Roli Rivelino
    January 28, 2011 at 11:04 am
    Ah OK, so keep everything to hand I guess.
    Many thanks Shane.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
