Activity Forums DaVinci Resolve EDL problems with scene cut
  • EDL problems with scene cut
    Posted by Sean Sartori on February 21, 2012 at 8:33 pm
    I am probably missing something, but I’m having an issue with EDL’s that are generated from scene cut detection.
    The spots are coming from Avid, so theyre exported to a ProRes file to grade. I split them in scene cut, and save the EDL. Then I load the EDL, with only that clip in the media pool, and everything looks good and I grade.
    Several days later I went back to do a revision, and when I opened the session, the EDL was scrambled. Cuts were in the wrong place, the grades were changing mid-shot, a big mess. Every time I reloaded that EDL, it came in this way. The only way to salvage the work was to start a new project, scene cut again, and re-apply saved grades.
    any thoughts?
    Sean Sartori replied 14 years, 6 months ago 3 Members · 4 Replies
  • Robert Due
    February 21, 2012 at 9:35 pm
    Make sure the frame rate is the same. Look in your config page. That will alter the ins and outs of shots.
    Robert Due
    Editor / Colorist
    INDEPENDENT EDIT
  • Sean Sartori
    February 21, 2012 at 10:20 pm
    frame rates are the same. Its not just a few frames, its like 4 or 5 seconds. Its like another EDL entirely, it doesn’t correspond to anything in the cut. It even has more cuts, and so has cut points in black, after the last frame. And this is the exact same EDL that I used originally, and it worked fine.
  • Laco Gaal
    February 21, 2012 at 10:24 pm
    is it possible, that the source file has changed?
    for example, you re-exported it, overwriting the old video file.
  • Sean Sartori
    February 23, 2012 at 6:01 pm
    nope. source file is the same.
