  • Posted by Gunleik Groven on August 15, 2008 at 7:50 pm
    Hi
    Have an EDL from AVID (yeah… I know…:) which actually imports quite fine, excepts from the clip-names being wrong.
    The EDL has all the right names and in- and outpoints, and a line from it looks like this:
    001 A001_C014_080726 V C 18:13:04:02 18:13:17:04 01:00:00:00 01:00:13:02
    Problem is that the files come in with the name V only, and I need the full name to match the files.
    NOW, these are short sequences and can be matched manually, but what goes wrong here?
    Cheers!
    Gunleik
    Gunleik Groven replied 18 years, 1 month ago 2 Members · 2 Replies
  • Stephan Walfridsson
    August 16, 2008 at 12:16 pm
    “A001_C014_080726 “ As this is the reel number you should find it under the Reel column in the browser, not as the clipname.
    /Stephan
  • Gunleik Groven
    August 17, 2008 at 12:18 pm
    Yes, found it
    It was trunctated, though – so I had to manually copy in the correct filenames.
    Worked in the end…
    https://www.vulture.no/
