Activity › Forums › Apple Final Cut Pro Legacy › EDL for Master Sequence
  • EDL for Master Sequence
    Posted by Dennis Bass on November 27, 2006 at 9:10 pm
    I want to capture footage from multiple sources, edit a master sequence in FCP, and then output back to a master Digi-Beta for storage. All that’s is easy. I now want to export an EDL of some type of the FCP sequence that I can use to recapture material from my master Digi. I can’t seem to export and import an EDL that doesn’t reference the original source tapes. Is this possible?
    Dennis Bass replied 19 years, 10 months ago 3 Members · 3 Replies
  • Bob Flood
    November 27, 2006 at 11:04 pm
    Hey Denneye
    No sure exactly what you are asking? do you want to creat a “video Archive” on a digibeta of the select footage you used to make your edit?
    OR
    are you looking for an edl that will identify all the cuts on your digibeta, but indicate them as coming form one reel ie the digibeta master, as if for color corrections?
    if 1, do a search for larry jordan. he has an article on “video archiving” using XML
    if 2, i believe its “digital heaven” has an edl tool that takes all your edits and makes em sources, specificall for finding cuts fast when you do color correction.
    hope this helps
    bee eph
  • Shane Ross
    November 27, 2006 at 11:12 pm
    It is possible, if you capture your digibeta, chop up the clip and use that footage in a timeline. An EDL ONLY REFERENCES the source footage, never the master tape. It will only reference the master tape if you capture it and use clips from it in a timeline, then export and EDL from THAT timeline.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Dennis Bass
    November 27, 2006 at 11:19 pm
    Thanks for the response. Option 1 is what I’m going for. I had read Larry Jordan’s archiving with XML article and guessed it would be the definitive answer, but wanted to check if there was another way to do it within FCP or without having to buy another app.
    Thanks again.
