Activity › Forums › Apple Final Cut Pro Legacy › EDL CMX3600 A-mode in FCP??
  • EDL CMX3600 A-mode in FCP??
    Posted by Sean Bale on May 18, 2009 at 12:17 pm
    I’ve been asked to export an EDL for ONLINE in standard CMX3600 A-mode…
    When in AVID, there is a “A-MODE” checkbox, when exporting this type of EDL…
    UNFORTUNATELY, this project is in FCP, and the “A-MODE” setting isn’t there!!
    I know it has something to do with sorting method; but not sure exactly what…
    How to I export an “A-MODE” cmx3600 EDL from Final Cut Pro? Which settings would do the trick?
    ANY help greatly appreciated !! THX!
    Sean Bale replied 17 years, 4 months ago 4 Members · 6 Replies
  • Rafael Amador
    May 18, 2009 at 1:20 pm
    Hi Soren,
    It seems that no A Mode in FC.
    I’ve found this thread:
    https://forums.creativecow.net/thread/8/915091
    I’ve been having a look in Google and there are some references to the CMX 3600 A Mode.
    I have the impression that this format was needed by AVID before the implementation of the EDL Manager.
    Rafael
    http://www.nagavideo.com
  • Timothy Auld
    May 18, 2009 at 1:24 pm
    In the EDL options sort by master. This is the equivalent of a mode assembly.
    But be warned, this is reliable mostly with simple cuts. Most effects wont translate. And don’t have more than 4 channels of audio.
    bigpine
  • Sean Bale
    May 18, 2009 at 1:28 pm
    THX!!
    But thats the case with EDLs in general right? (that most effects wont tranfer)
    The EDL is for online at a post-house. All FX-work will be done later.
    BUT; I have done several speed-changes in clips (not keyframed variables, just constant speed alterations) and a few dissolves. Will those transfer?
  • Bob Flood
    May 18, 2009 at 2:29 pm
    Soren
    Simple a to b effects, like wipes and dissolves, generally translate well
    although the info is just speed and direction.
    speed changes may not, and usually because cmx speed notation is a note called a Motion Memory or M2 that some systems can read and others cant.
    you should contact someone at the post house who has done this workflow, and find out what he/she needs, and how they address issues.
    hope this helps
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Timothy Auld
    May 18, 2009 at 3:16 pm
    Dissolves are probably OK. As speed changes would involve controlling the dynamic tracking of a tape machine I’m guessing not.
    Your best bet is to arrange to do a test with your post house to determine what does and doesn’t work.
    bigpine
  • Sean Bale
    May 19, 2009 at 1:21 pm
    THX so much for the help!
