Activity Forums Apple Final Cut Pro Legacy EDL batch capturing question
  • EDL batch capturing question
    Posted by Donat Van bellinghen on February 8, 2006 at 10:48 pm
    I’m not an FCP user but I’m wondering how FCP works with imported EDL’s
    Suppose that you’d be given an EDL from an offline edit. In this EDL you’d have a few versions of a commercial. For instance you’d have the same wide shot xyz being used multiple times, but with slightly different source in-out timecodes.
    When you import this EDL in FCP, is there a way to concatenate the events so that you only have to digitize the wide shot once, encompassing all the needed footage ?
    Regards.
    Donat
    Donat Van bellinghen replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
