Activity › Forums › Adobe Premiere Pro › Editing workflow on a network hard drive for multiple systems…..yes or a better solution?
  • Editing workflow on a network hard drive for multiple systems…..yes or a better solution?
    Posted by Mikkell Khan on September 10, 2009 at 12:47 pm
    Hey, do any of you work on a network hard drive, one that is connected via ethernet to a router?
    How do you find it works with your editing if your system was connected directly to the router via another ethernet cable?
    And how about wirelessly?
    Essentially, I want to share project files amongst 3 different systems in the same room and would like to create a fast and possibly uninterrupted workflow with them (one for basic and final editing, one for special effects, one for audio cleanup/sound and music creation).
    A network hard drive is what I have thought about. Does anyone use any other methods that might be better for this situation?
    Mikkell Khan
    Director
    Diamond Films Ltd. (Trinidad and Tobago)
    Alex Udell replied 17 years ago 3 Members · 2 Replies
  • Jeff Brown
    September 10, 2009 at 2:29 pm
    If you are doing SD DV, maybe.
    Do a search on “Storage Area Network” or “SAN” and “video”.
    A lot depends on where you need realtime playback.
    -Jeff
  • Alex Udell
    September 10, 2009 at 5:36 pm
    Hi….
    Bob Zellin has discussed this at length…
    https://forums.creativecow.net/sanetworks
    hope that helps….
    look to hardware from Small tree communications and perhaps software like MetaLan from Tiger Technology.
    Alex
