Activity Forums Blackmagic Design Editing Uncompressed High Def on G5?
  • Editing Uncompressed High Def on G5?
    Posted by Joe Campanale on February 11, 2008 at 10:17 pm
    Hi guys,
    We are intending to capture uncompressed Hi Def Video via SDI into a Quad PowerPC G5(woodcrest), with 8 gigs of RAM. We have the a 1.5 year old Xserve RAID, 2.73Tb, and were looking to capture with the Blackmagic HD Extreme Card.
    Do you guys foresee any problems/dropped frames/crashes/etc?
    Any help would be greatly appreciated! Thanks!
    Joe
    Del Chapple replied 18 years, 7 months ago 3 Members · 2 Replies
  • Kristian Lam
    February 12, 2008 at 7:02 am
    Hi Joe,
    G5s are certainly capable of doing uncompressed HiDef video. The only bottleneck in the setup will be the speed of your disk drives. The Xserve RAID should be ok.
    regards
    Kristian Lam
    Blackmagic Design
  • Del Chapple
    February 15, 2008 at 5:42 pm
    just make sure you are running raid 1 across the entire raid frame, i’d have at minimum 4 drives per side and you’ll be fine.
    del
    you cant hear my inner voice scream… can you..?
