Activity Forums Apple Final Cut Pro Legacy Editing System Configuration
  • Editing System Configuration
    Posted by Jessica Kehrhahn on March 2, 2010 at 3:13 am
    Hallo,
    I am looking for some advice on what kind of editing configuration to purchase for a documentary shot on the Sony XDCam, the files I’ll be working with in FCP are XDCAM EX 1080p 24 (35 Mb/s).
    We’re thinking of getting the Mac Pro 8 core, Apple Monitors (2×24,1×30) and CalDigit Drives. Unsure on how much Memory is needed, if we need a Blackmagic or similar card and if anything else is missing?
    Jessica
    Jessica Kehrhahn replied 16 years, 6 months ago 2 Members · 2 Replies
  • Herb Sevush
    March 2, 2010 at 3:26 pm
    Jessica –
    Recommended memory is at least 1 gig per core – in your case 8 gigs, at a minimum. More is always better.
    You’re getting a lot of monitor real estate – The apple monitors are expensive, I would suggest looking at Dell and HP alternatives – high quality at almost half the price. The type of monitors you need will also depend on whether or not you are getting an I/O card.
    You don’t need an I/O card but you will be stuck monitoring within FCP using the cinema desktop – not the optimum way to go. I’d recommend getting the best I/O card you can afford – you might not need the AJA Kona3 (around $2500) but if you have $1500 the AJA Lhi; otherwise Blackmagic and Matrox have less expensive options.
    Cal Digit makes excellent drives, however you didn’t say which of their drives you are looking at. For a setup like yours I would recommend a protected raid set, typically raid-5. This will require a raid card as part of the package. You can get away with firewire drives, but it would be pennywise and pound foolish.
    Something else to note – Apple is going to be coming out with a revised MacPro in the coming months based on the new intel i7 chips. If you can wait to buy till after they come out, it might be worth your while.
    Herb Sevush
    Zebra Productions
  • Jessica Kehrhahn
    March 2, 2010 at 5:35 pm
    Thanks Herb!
    I wasn’t planning on getting an I/O Card, instead I thought I get a second Graphics card and have the 30″ Apple display as my 3rd monitor, but maybe it is better to spend some money on a card, and use Dells instead of the Apple monitors?
    As for drives, I was looking at the CalDigit HDOne Drives.
