Activity › Forums › Avid Media Composer › editing SD and HD together
  • editing SD and HD together
    Posted by Jack Entonces on May 14, 2009 at 9:19 pm
    I’m working with Avid Media Composer.
    I have a project with multiple source video,
    some SD other HD formats.
    I have both different formats on my timeline,
    but I want to output the project as HD.
    Can someone tell me how do I set it up so that
    my Digital Cut is in HD format? Most likely, it will be output to
    tape.
    thanks!!
    James Beattie replied 17 years, 4 months ago 4 Members · 4 Replies
  • Michael Phillips
    May 14, 2009 at 11:20 pm
    Select timeline and do a transcoded to the DNxHD format of your choice. Once all media is HD, you can output to your master tape.
    Michael
    Michael Phillips
  • John Kennedy
    May 15, 2009 at 2:53 pm
    Also, depending on the amount of work you will be doing and your budget… for future projects you can pick up a box from teranex. (https://www.teranex.com/) This will basically upconvert any SD 4:3 footage to 1080p. It does alot more than that, but this is just one of the features.
    Avid Adreneline – MC 3.1
    Avid Nitrous – Symphony
    Avid Mojo – MC 3.0.1
    Final Cut Pro 6.0.3
  • Jack Entonces
    May 15, 2009 at 7:48 pm
    thanks guys, thanks very much!
  • James Beattie
    May 20, 2009 at 12:49 am
    As is always the case, make sure you do a test output before you get to cruch time. Pushing it to the last minute will guarantee failure.
