Activity Forums VEGAS Pro Editing Q: How to Apply a Dissolve Only to the Video Track
  • Editing Q: How to Apply a Dissolve Only to the Video Track
    Posted by Jake Zeer on October 11, 2007 at 1:58 pm
    I saw in Avid how you can turn off the Audio Track and apply a Dissolve and only the video track will be dissolved between the two clips and the Audio will just snap together but stay in sync with the video.
    Currently I stretch my video to hang over the side of my audio one frame so I can do the dissolve without affecting the sound. Now how is that for a primitive beginners workaround?
    Gary
    Edward Troxel replied 18 years, 11 months ago 3 Members · 6 Replies
  • Jake Zeer
    October 11, 2007 at 2:30 pm
    I right clicked on the video track and chose ‘crossfade’ and lo and behold it only applied to the video track and not the audio.
    Was that what I should be doing or is there another way?
  • Edward Troxel
    October 11, 2007 at 3:29 pm
    You can turn on “ignore event grouping” and adjust only the video or audio (don’t forget to turn it off afterwards). You can also use a script to adjust only one or the other. There’s many ways you can do this.
    Edward Troxel
    JETDV Scripts
  • Don Bloom
    October 12, 2007 at 10:08 am
    you can also put the cursor over the cut in the video track press the “/” key on the NUMBER PAD (must be on number pad) and PRESTO! instant dissolve and the audio doesn’t and stays in sync.
    Don
  • Jake Zeer
    October 12, 2007 at 11:12 am
    now that one I really like. Thanks to everyone for the help
  • Jake Zeer
    October 13, 2007 at 7:30 pm
    Is there a way to change the default time? I see it’s set to 6 frames.
  • Edward Troxel
    October 13, 2007 at 10:40 pm
    Options – preferences – editing tab. Change the “cut to overlap conversion” length.
    Edward Troxel
    JETDV Scripts
