Activity Forums VEGAS Pro Editing part of a video to play backwards?
  • Stephen Mann
    February 14, 2011 at 1:43 pm
    From the help file, under Event Envelope:
    Right-click a video event, choose Insert/Remove Envelope from the shortcut menu, and then choose Velocity from the submenu. A velocity envelope is drawn on the event.
    Drag the envelope up to increase the playback speed of the event, or drag down to decrease its speed.
    Setting a velocity envelope to a negative value will cause the event to play in reverse. Video events can only be reversed if there is media to reverse: an event cannot be reversed past the beginning of a media file. An event that has been reversed will play backwards until it gets to the first frame and will then hold that frame for the duration of the event.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • John Faulkner
    February 14, 2011 at 11:03 pm
    Thanks very much Stephen – it looks a little difficult for my level, but definitely worth playing around with.
    Regards, John
  • Matt Crowley
    February 15, 2011 at 9:34 am
    In Movie Studio you don’t get velocity envelopes but you can still reverse a video event (clip). I guess you can do the same in Vegas Pro.
    Simply right-click the event, and click Reverse. A check mark will appear next to Reverse to indicate the event is reversed, and it will play backwards at normal speed.
