Activity Forums VEGAS Pro Editing mpeg-2
  • Editing mpeg-2
    Posted by Amiel Jonathan on December 9, 2007 at 6:57 pm
    sony vegas 6.0 and im recording footage with panasonic VDR-D150 that recoreds directly to DVD disc mpeg-2 VOB files.
    every time to convert the files couse sony dosnt recon them? isnt there any plug-in to do the job? what about vegas 8.0? or do need to use miniDV cam?
    Paul Dana replied 18 years, 9 months ago 3 Members · 3 Replies
  • Paul Dana
    December 9, 2007 at 7:31 pm
    Hi there.. Every time an mpeg is created or re-created, you are at the mercy of the software that is doing the job. The quality can be severely compromised! For best results, connect the camera to the computer using the 1394 connection. Open Vegas and use the capture function (File>Capture Video). Start a new project when the capturing is complete (File>New), select the explorer, find your new clip, drag and drop it to the timeline and proceed with your edits.
    If no editing is required and don
  • Edward Troxel
    December 10, 2007 at 2:28 pm
    To pull the files into Vegas, go to File – Import – Camcorder DVD Disc. I believe this was added in 6.0c so if you’re on an older version of 6 you’ll need to update to the last version of 6.
    Edward Troxel
    JETDV Scripts
  • Paul Dana
    December 17, 2007 at 4:24 pm
    Ignore my previous post about capture. This works but, of course, Ed is SO correct! …and importing the file his way is much faster.
