Activity Forums VEGAS Pro Editing JVC 250U HDV 30 footage
  • Editing JVC 250U HDV 30 footage
    Posted by Larry Watts on October 20, 2008 at 3:35 pm
    I am wondering about editing footage shot on our JVC 250 U camera.
    How does Vegas handle the same footage files in
    1. A DV Widescreen project
    2. A HDV 720 30 project?
    Will Vegas downsample the project example 1? so it will not be burdened with larger files? Will it still access higher res files in any way?
    Or will both 1. and 2. handle it the same way?
    I assume a HDV 720 – 30p project will yield the highest image quality, but by how much?
    What are some workflow options?
    Should I open it up in an HDV project and render to a DV project for the smallest project?
    THanks
    Larry
    Kert replied 17 years, 11 months ago 2 Members · 3 Replies
  • Kert
    October 21, 2008 at 4:13 am
    You can put both DV and HDV (and nearly any other footage) on the time line and just edit. When want to export you specify the the code for the export (DV, HDV, MPG, AVCHD etc). Vegas will convert approprietly.
    JK
  • Larry Watts
    October 24, 2008 at 4:03 pm
    Thanks John,
    That is what I’ve thought, but all three editors here are havy problems with the HDV footage and heard service pack three may be causing troubles.
    We are having rendering failures and Vegas stop responding .
    Larry
    Vegas 8.0C
  • Kert
    October 25, 2008 at 2:04 am
    I used to have the “Vegas not responding” message. Since I switched to Quad Core computer (Intel Q6600), Vegas breazes through HDV, AVC HD, M2V etc.
    I think Vegas chokes on slower computers because it can not decompress HDV, AVCHD fast enough.
