Activity Forums Apple Final Cut Pro Legacy Editing Issue with DVCPro50 and Format
  • Editing Issue with DVCPro50 and Format
    Posted by Francisco Bech gómez on October 26, 2009 at 4:36 pm
    Hello to everyone, I am editing in native DVCpro 50. In the canvas I get a thin black line left and right, so the footage is not completely covering the canvas view. Should I resize the footgae a little bit to match this?
    My problem is that I am bringing pictures to the project so I dont know if I should adjust them to the canvas or to the slightly smaller frame of the footage, this would be a hard work to make everything equal
    Thanks for your help
    David Roth weiss replied 16 years, 6 months ago 4 Members · 19 Replies
  • 19 Replies
  • Shane Ross
    October 26, 2009 at 5:11 pm
    DO your sequence settings match the clip settings? Because DV50 is 720×480, and uncompressed SD is 720×486…so there might be something there. But I doubt you’d see the 6 pixels though…
    Can you post a pic?
    Shane
  • Greg Nosaty
    February 25, 2010 at 5:36 pm
    [Shane Ross] “DO your sequence settings match the clip settings? Because DV50 is 720×480, and uncompressed SD is 720×486…so there might be something there. But I doubt you’d see the 6 pixels though… “
    Hi Shane
    I searched the forum to shed some light on a concern I’m having with a DVCPro50 project that was shot and ingested in 2007 as ProRes 422 HQ. We are versioning the show in English and I’m noticing black lines on the vertical edge of the frame. I thought that DVCPro50 was 720×486. Is it true that it’s only 480? How have you dealt with this type of issue.
    I’ve checked the original French DigiBeta master and I see the same line in under scan. The show passed QC so I assume I can do the same this time around or should I blow the show up by a few pixels to be safe. That’s a heck of a lot of render time that I would like to avoid.
    Thoughts?
    Cheers, greg
    cheers,
    Greg Nosaty
    Cinemontage Productions Inc
  • Shane Ross
    February 25, 2010 at 5:39 pm
    [Greg Nosaty] “I thought that DVCPro50 was 720×486. Is it true that it’s only 480? “
    I’m sure. It is only 480. [Greg Nosaty] “How have you dealt with this type of issue. “
    Left it. It is outside of TV safe, and no network has rejected a show because of this format.
    [Greg Nosaty] ” The show passed QC so I assume I can do the same this time around”
    There you go. Things are fine.
    Shane
  • David Roth weiss
    February 25, 2010 at 5:42 pm
    Like Shane says, DVCPro50 is 720×480 like all DV.
    You can scale the shots up in even increments 2% or 4% if you wish, but keep in mind, what you’re seeing in the FCP canvas is “full frame,” the blanking you’re seeing will be outside of TV safe.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Greg Nosaty
    February 25, 2010 at 8:31 pm
    Thanks Shane and David
    Is there a way to adjust the the horizontal blanking width in FCP?
    cheers, greg
    cheers,
    Greg Nosaty
  • Shane Ross
    February 25, 2010 at 8:33 pm
    The horizontal blanking is on the tape itself…not something that FCP does. Again, this is outside title safe, and perfectly acceptable for QC, so I fail to see what the problem is.
    Shane
  • David Roth weiss
    February 25, 2010 at 9:00 pm
    If it bothers you, the only solution is to scale up in even numbered increments as I told you before. No one will notice.
    David Roth Weiss
    Los Angeles
  • Greg Nosaty
    February 25, 2010 at 10:30 pm
    There IS NO problem.I don\’t seem to see these issues working in HD and it\’s been 3 years since I\’ve worked in SD.
    It\’s just a bit perplexing to see one thing in FCP, that is different, from what I see on the DBC deck whether it is set to H-BLK wide or narrow.
    cheers,
    Greg Nosaty
  • Shane Ross
    February 25, 2010 at 10:36 pm
    [Greg Nosaty] “I don\’t seem to see these issues working in HD”
    because HD doesn’t have these differing formats. SD is 720×486, from BETA and DIGIBETA and 3/4″ and MII and most other formats. DV and DVCPRO 50 just happen to be 720×480…so there is vertical blanking. That is their FORMAT…not an FCP issue. There is no 1920×1072 (as opposed to 1080) format that would compare. Everything in HD, no matter the format, conform to the same pixel dimensions (sorta…anamorphic exceptions, but they don’t count in this comparison).
    [Greg Nosaty] “It\’s just a bit perplexing to see one thing in FCP, that is different, from what I see on the DBC deck whether it is set to H-BLK wide or narrow. “
    DBC deck? Digibeta?
    Shane
  • David Roth weiss
    February 25, 2010 at 10:54 pm
    [Greg Nosaty] “There IS NO problem.I don\’t seem to see these issues working in HD and it\’s been 3 years since I\’ve worked in SD.”
    Correct, HD televisions and thus HD signals don’t have the same large area outside of TV safe. What do you expect, SD TV was designed in the 1800’s.
    Here’s a taste of what you’ll find on Wikipedia if you look up the history of TV:
    “As a 23-year-old German university student, Nipkow proposed and patented the first “near-practicable” electromechanical television system in 1884.[1] Although he never built a working model of the system, Nipkow’s spinning disk design became a common television image rasterizer used up to 1939.[2] Constantin Perskyi had coined the word television in a paper read to the International Electricity Congress at the International World Fair in Paris on August 25, 1900.”
    David Roth Weiss
    Los Angeles
