Activity Forums DaVinci Resolve Editing in Fairlight – 1st second of audio does not play from play head
  • Editing in Fairlight – 1st second of audio does not play from play head
    Posted by Don Cobble on October 29, 2020 at 6:46 pm
    Trying to edit out a noise in an audio clip precisely, but when i put the playhead on what i think to be the beginning of the noise, fairlight will not play the 1st second of audio. So i have to place the play head 1 second before what I want to hear, therefore making a precise cut next to impossible because having to do it on the fly. I have changed everything I know to change. Is this a bug in DR Studio 16 or is there a setting i can change??
    Thank You
    dc
    Don Cobble replied 5 years, 10 months ago 1 Member · 1 Reply
  • Don Cobble
    October 30, 2020 at 2:06 am
    Found the answer on another Forum, It was a VST plugin causing the delay, so I deleted it, it was not enough to bypass it, still cause delay, so deleted it finish the edit then applied the VST and it worked out ok, Little work around
    DC
