Activity Forums Apple Final Cut Pro Legacy Editing HDV into SD Sequence
  • Editing HDV into SD Sequence
    Posted by Peter Archibald on June 15, 2007 at 3:51 am
    Hi from New Zealand.
    I have HD footage that I want to edit into a SD 4:3 ratio sequence. I know the HD footage will have crop lines at the top and bottom. I can place HD footage into the sequence and use the Motion/Scale feature to scale the footage to 49%. I don’t think that this is the best way to achieve a quality SD edit result. Can anyone help??
    Cheers…Pete
    Russell Lasson replied 19 years, 2 months ago 2 Members · 1 Reply
  • Russell Lasson
    June 20, 2007 at 12:08 am
    If you want the footage letterboxed, you can use compressor to downconvert the footage to SD and letterbox it at the same time. Just create a custom setting and add the letterbox filter.
    -Russ
