Activity Forums Apple Final Cut Pro Legacy editing flv in fcp with perian plugin
  • editing flv in fcp with perian plugin
    Posted by Matthew Stewart on June 19, 2012 at 7:33 pm
    I am editing a flv I found on youtube in fcp with the help of the perian plug in which makes flv files compatible with quicktime based apps. My problem is that the flv file is 10 fps, is it possible to set the sequence editing timebase to 10 fps? and the audio depth is 32 bit floating point, which is also not available in the sequence audio settings pulldown menu. much appreciated if anyone can help me out with this…
    Matthew Stewart replied 14 years, 2 months ago 3 Members · 5 Replies
  • Shane Ross
    June 19, 2012 at 7:37 pm
    Just because you can import it, doesn’t mean that it works. FCP doesn’t work with FLV, no matter what plugin you get.
    You MUST convert the footage to a codec FCP works with. Like ProRes, or if it isn’t HD, then DV/NTSC.
    Shane
    Little Frog Post
  • Matthew Stewart
    June 19, 2012 at 7:42 pm
    thanks for responding so fast, ive been stumped on this. what do you recommend using to convert the flv into a dv/ntsc file? the clips are 640 x 480.
  • Shane Ross
    June 19, 2012 at 7:43 pm
    Compressor. Comes with FCP. MPEG STREAMCLIP…free app you can download.
    Shane
    Little Frog Post
  • Steve Eisen
    June 19, 2012 at 7:44 pm
    Try DV NTSC 720×480 or ProRes 720×486.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Matthew Stewart
    June 19, 2012 at 8:01 pm
    danke, much obliged.
