Activity › Forums › Apple Final Cut Pro Legacy › editing DVD on Final Cut
Posted by Fábio Rodrigues on May 9, 2010 at 3:51 pmI need to edit a DVD content in Final Cut.
I exported it tp .mov using “mpeg stream clip” but the result of that has no sync. I’ve tried some different configurations, but the problem didn’t change.
What could I do?thanks
FábioFábio Rodrigues replied 16 years, 3 months ago 2 Members · 4 Replies -
John Fishback
May 9, 2010 at 5:47 pmDescribe what you did in more detail. What codec did you export to for use in FCP?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Fábio Rodrigues
May 9, 2010 at 6:32 pmI don’t know if all these informations are enough for you,
but here they are:Compression: Apple Motion JPEG A
Sound: Uncompressed / stereo / autoFrame size: 640 X 480 (4:3)
Interface scalling
Reinterlace chromaField Dominance: upper field first
Rotation: no -
John Fishback
May 9, 2010 at 8:37 pmI don’t believe JPEG A is an edit codec. You should try with one of the codecs that appear in FCP’s Easy Setups. They are all edit codecs. A couple of codecs which should work are ProRes or DCVPro50 (DV50). Try one of those and see if it works better for you.
John
Fábio Rodrigues
May 11, 2010 at 3:02 amJohn,
I`ve tried your suggestions and some others,
but I yet didn`t get sync.
Are there any other way?thanks
Fábio
