Activity › Forums › Creative Community Conversations › Editing Disconnected Audio
Aindreas Gallagher
March 11, 2013 at 9:38 pmonly to watch you all scrabbling around trying to keep it alive. It’s.. entertaining.
https://vimeo.com/user1590967/videos http://www.ogallchoir.net promo producer/editor.grading/motion graphics
Aindreas Gallagher
March 11, 2013 at 10:18 pm[Charlie Austin] “the tail you cut off jumps all the way to the top of the screen. Or worse, cutting 2 or 3 frame bits of dialog or FX together. You may not care about that, but those that do may think Roles really need to be able to stick together, at least loosely. :-)”
that – in truth – would drive me a bit around the bend – I’ve just mucked around faking that up – there’s no way to force them back into alignment is there?
Charlie Austin
March 11, 2013 at 10:26 pm[Aindreas Gallagher] “that – in truth – would drive me a bit around the bend – I’ve just mucked around faking that up – there’s no way to force them back into alignment is there?
“Well, I usually cut DIA at the top of the timeline, so it sticks together, And if I’m chopping up MX I have a 5 min silent clip that I use as a… barrier i guess, to keep it all together at the bottom. It does require moving bits below it as needed, but once there they stay put. I can’t see why they can’t make ’em stick together… we’ll see.
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Bernard Newnham
March 11, 2013 at 10:36 pm[Aindreas Gallagher] “only to watch you all scrabbling around trying to keep it alive. It’s.. entertaining.”
Yes – I keep coming back for the same reason.
Someone the other day was singing the praises of the Quantel Harry three strip editor. I don’t know if it was good or not. It may have been the best ever – I never operated it, just had people do stuff for me. Whatever – where is it now? The world stuck with Avid style timelines, and that was that. I think the same will happen here.
And I don’t understand what people are on about when they talk about “what Apple will do with the MacPro replacement”. It’s a PC for goodness sake, which runs a different, Unix based operating system. Unless they go ARM (good for my shares in the company), the new one will be like the old one but faster.
If they bother.
Bernie
Craig Seeman
March 11, 2013 at 10:49 pm[Bernard Newnham] “And I don’t understand what people are on about when they talk about “what Apple will do with the MacPro replacement”.”
It’s Xeon (I suspect) with Thunderbolt. That’s not in any PC.
Also how they handle the GPU will be interested as it may not be quite the same as how the ASUS motherboard handles it. -
Bernard Newnham
March 11, 2013 at 11:12 pm[Craig Seeman] “It’s Xeon (I suspect) with Thunderbolt. That’s not in any PC.”
I think that may be because current Xeons are quite old. The PC market changes by the day, so if Asus or whoever think they can make money out of some new Xeon and Thunderbolt they’ll build the boards pretty much instantly.
Bernie
Steve Connor
March 11, 2013 at 11:13 pm[Bernard Newnham] “which runs a different, Unix based operating system”
Which a lot of us like
[Bernard Newnham] “the new one will be like the old one but faster.
“Let’s hope so
[Bernard Newnham] “If they bother.”
It’s already well documented that they are
[Bernard Newnham] “[Aindreas Gallagher] “only to watch you all scrabbling around trying to keep it alive. It’s.. entertaining.”
Yes – I keep coming back for the same reason.”
The FCPX Techniques forum is very entertaining too, It’s not busy over there at all!
Steve Connor
There’s nothing we can’t argue about on the FCPX COW Forum
Steve Connor
March 11, 2013 at 11:14 pm[Aindreas Gallagher] “only to watch you all scrabbling around trying to keep it alive. It’s.. entertaining.
“As you used to be
Steve Connor
Aindreas Gallagher
March 11, 2013 at 11:16 pmok quite – you’re a country mile beyond me in process – as I said below to garchow – I really amn’t that ignorant of the software at this point.
But it’s impossible to develop work process solutions when its a hobby on the side.[Charlie Austin] “And if I’m chopping up MX I have a 5 min silent clip that I use as a… barrier i guess”
grand – so that audio slug functions as an edit length track barrier to corral nats from sync? that stuff can only bounce so much?
