Activity Forums VEGAS Pro editing AVCHD files and file numbering
  • editing AVCHD files and file numbering
    Posted by Doug Kereszturi on September 13, 2011 at 4:23 pm
    Hello ALl,
    I am starting to edit a project using AVCHD files. First, it seems that when I import files from different folders with the same number, one file gets cancelled out. Is there a simple way to rename files so that they are still recognized without cancelling?
    Second the footage shot in the ceremony was shot at +6 db. The footage is pretty dark. Any suggestions on making the footage brighter. Any help would be great
    Thanks in advance
    Doug
    Matt Crowley replied 14 years, 11 months ago 3 Members · 3 Replies
  • John Rofrano
    September 14, 2011 at 12:57 pm
    [Doug Kereszturi] “First, it seems that when I import files from different folders with the same number, one file gets cancelled out. Is there a simple way to rename files so that they are still recognized without cancelling?”
    Use the built-in Device Explorer in Vegas (View | Device Explorer). It will rename the files with date and time plus a sequence number so the names should be unique.
    [Doug Kereszturi] “Second the footage shot in the ceremony was shot at +6 db. The footage is pretty dark. Any suggestions on making the footage brighter.”
    Use Levels and Color Curves to make the footage brighter.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Doug Kereszturi
    September 27, 2011 at 4:31 pm
    John,
    I was able to open the device explorer but when I attempt to import my files from the Hard Drive it does not allow me to do so. Any thoughts?
  • Matt Crowley
    September 27, 2011 at 6:03 pm
    The Device Explorer is really designed for “capturing” footage from cameras that record to hard disk or memory cards – typically AVCHD, I’ve only used for AVCHD camera, and it expects to see the original file/folder structure that the camera creates. It won’t work if you just have a folder of MTS files. My main gripe with it is that it seems to put all files into a specific folder, and you can’t select where to put the imported files.
    One workaround I’ve used is to batch rename the files to include a date/time in the name (much as camera import utilities do). I use Renamer and a rule that adds the “file modified” date/time, but you can also try BulkRenameUtility. They’re a bit complicated but powerful.
    It’s very easy to get confused with multiple AVCHD files that have the same name (00001.MTS, 00001.MTS etc) so get into the habit of renaming them or using an import utility that gives them a timestamp in the name.
