Editing audio clips in timeline and source monitor
Hi all,
This is probably a simple procedure, but I’m wading through a lot of searches trying to find it. I’m using Pr CC 7.2.2
I had a long VO clip that I edited using ins and outs and saved as many separate subclips each with their own name and text cue.
When I bring these into the timeline they look OK with waveforms and sound OK.
When I double-click from the PROJECT MANAGER they appear in the SOURCE MONITOR, I can see the waveforms and edit the clip further and save/rename.
When I double click from one of these clips in the TIMELINE something with waveforms appears in the SOURCE MONITOR; it seems like the entire source clip is what plays; I can’t figure out how to scroll to the selected section and cut/edit.
I can hugely blow up/magnify the TIMELINE to show waveforms and cut on that basis but can’t figure how to do it in the SOURCE MONITOR.
Seems like it should be easy to trim these in the SOURCE MONITOR from the TIMELINE but can’t see the selected portion.
Thanks if you can follow this convoluted description.
RobertRobert Withers
Independent/personal/avant-garde cinema, New York City
